Here is one option: Item 3 - Fuel Filter Kit part #AVEN003 Application 90-96 300ZX (TT requires a slight modification) List Price = $300.00 Discount Price = $275. 00 It comes with everything you need. The other is #6 braided steel. If you use the stock fuel filter, the nipple should be cut and then properly fitted with an AN fitting or NASCAR spec double clamps.
Regards : What do I need to know to change the fuel line from the fuel filter from the stock rubber line to steel braided : ( Diameter / length / install ? ) ? : Any suggestions on where to go to get the parts?
: thanks guys !
 2000 ZCCA Gold Medallion Recipient for Concourse Excellence Member - Professional Detailers Assoc and the ICA |
